August 29, 2006, 12:01 |
Gambit Boundary Layers
I have a problem with creating a boundary layer in Gambit. Imagine a horizontal pipe of large diameter suddenly contracting to a smaller diamter. How do I go about attaching a boundary layer to the vertical wall that forms the contraction. I have to model this in 3d as the rest of the geometry is quite complex - it's easy to do this in 2D but I can't figure it out in 3D. Any help would be much appreciated. Thanks, Mike |
August 29, 2006, 18:43 |
Re: Gambit Boundary Layers
Hi Mike,
Imagine a pipe 200mm in length and 30mm in dia extruded in the positive Z direction and a pipe with 100mm length and 10mm in dia extruded in the negative z direction. with a single volume of the 2 pipes.open the boundary layer option and the set the a value and then select faces instead of edges. select the outer face. this means that your prism elements faces are perpendicular to the flow. Hope these are helpful. Regards Rajit |
August 30, 2006, 02:49 |
Thanks Rajit,
I think the single volume is where things may have been going wrong. Regards, Mike |
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh | tomyangbath | FLUENT | 18 | October 12, 2016 06:57 |
[Gmsh] gmsh and boundary layers | kanuk | OpenFOAM Meshing & Mesh Conversion | 11 | August 14, 2015 12:35 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Gambit 2 Boundary Layers | An Modh Coinniolach | FLUENT | 2 | January 30, 2002 11:54 |
