Home > Forums > FLUENT
Transition Prediction
Old   August 30, 2006, 02:18
Default Transition Prediction
Pete
I'm currently working on a project on prediction of transition from laminar to turbulent flow and its effect on drag for various airfoils.
I just have started using CFD (Fluent) and I've only covered basics so far. My question is if there is a fairly easy way to predict transition or if this would be way to difficult for a simple uni project?
Cheers, Peter
Old   August 31, 2006, 11:43
Default Re: Transition Prediction
Evan Rosenbaum
If by simple uni project you mean PhD thesis, then it might be a good project. If you mean a short project for a class, no way. One problem is that different parts of the foil will undergo transition at different times. It isn't just when transition will occur, but when and where. A second problem is that transition isn't a lightswitch. It could occur differently for different areas on the foil.
There is a reason that the aerospace industry typically designs a wing to be either laminar always or turbulent always.
Old   September 6, 2006, 18:55
Pete
Thank you for your answer! It would be only a short project for a class, so I better look for a different project. But thx anyway!
Thread Tools
Trackbacks are On
e-N method transition prediction morteza08 Main CFD Forum 0 August 22, 2010 04:12
Where can I get a free software with e^N method for transition prediction? peter.zhao Main CFD Forum 4 January 4, 2010 10:28
Transition prediction Shawn Choy FLUENT 0 December 8, 2008 03:16
Transition prediction, new CFD-Wiki chapter Jonas Larsson Main CFD Forum 6 April 30, 2007 15:29
Prediction of Laminar to Turbulent Transition HN Das FLUENT 0 September 22, 2004 07:16
