August 31, 2006, 10:59 |
Eulerian Model, Packing limit
hi everybody
could anybody explain me the term "packing limit" when we use eulerian multiphase model and if we change this value, how is it goona effect the distribution of the solid phase (granular) in the fluid phase Thanks Hassan |
August 31, 2006, 14:46 |
Re: Eulerian Model, Packing limit
The packing limit is the highest solids volume fraction that is possible in a computational cell. The default value of 0.63 is derived from stacking monodisperse spheres as far as I can remember.
Its really only a limiter thats implemented numerically. The physical value of the limit depends on the type of material in use. For example, particles with varying diameters would have a higher packing limit because the small particles would fill the gaps between the bigger ones. Increasing the limit will allow more of the granular phase per unit volume and decreasing it will have the opposite effect. |
August 31, 2006, 15:39 |
thanks a lot Cadie i got ur point.
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Eulerian Multifase model with species transport | Valeria | FLUENT | 0 | July 19, 2008 16:48 |
eulerian model | mvee | FLUENT | 1 | December 6, 2007 11:47 |
Eulerian Model | Hassan | FLUENT | 2 | September 1, 2006 07:39 |
Strain Rate in eulerian model | galeazzo | FLUENT | 0 | January 25, 2005 07:52 |
