Home > Forums > FLUENT
Mesh independence
Old   September 1, 2006, 03:24
Default Mesh independence
Mark
I am modelling annular flow as 2D axisymetric (g=0).I used two different mesh scheme but finer mesh's result is not as good as coarse mesh result although all solver setting is same. Could you please help me ?
Thanks already
Old   September 1, 2006, 04:47
Default Re: Mesh independence
Mark Russell
Did they both converge? To what level of residual are you using to 'stop' the solving process?
Old   September 1, 2006, 13:24
Evan Rosenbaum
Also, if the flow turbulent? If you are using standard wall functions and the finer mesh has multiple cells in the boundary layer it will give the wrong answer. If this is the case, you could switch to enhanced wall treatment.
Thread Tools
Trackbacks are On
Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Native Meshers: snappyHexMesh and Others 11 January 13, 2015 12:47
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Mesh Independence - Valid Strategy? Ianto Main CFD Forum 2 August 31, 2009 04:36
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 16:50
