September 2, 2006, 01:00 |
solution is oscillating after 500 iterations
I am an aerospace Engg student.I have to simulate flow past two buildings in tandem arrangement.i m using standard k-epsilon model.flow in coming in through one face where velocity-inlet condition is specified.in other 4 sides of the domain is specified as outflow B.C.in the walls the standard wall function is activated.i have taken around 9 lakhs os hexahedral cells.the domain dimensions are 20x12x8.the building dimensions are 0.5x0.5x1 & 0.5x0.5x2.the under relaxation factors r 0.7 for pressure & 0.3 for momentum.i m using steady segregated solver for 3d. the problem is that after say 500 or 100 iterations the residuals start to oscillate & reverse flow through the outflow boundary takes place, though initially they monotonically decreases.can u suggest any remedy? Swagata
September 5, 2006, 00:27 |
Re: solution is oscillating after 500 iterations
Hi Swagata,
Rather than declaring outflow consider using pressure outlet. This should fix the problem. Regards Rajit |
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 02:18 |
Tubrogrid - Error on cut-off at TE | Flavio | CFX | 5 | January 12, 2017 09:41 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
