re:abt vof
Old   September 6, 2006, 05:24
Default re:abt vof
ravi
hi, i want to do for a simple mesh, i specified one boundary as mas flow inlet, another as pressure outlet and remaining two as wall, and i tried to solve using vof, method by specifying mass flow rate, but i cannot able to get the result.can any body tell,is it possible to specify a mass flow rate using vof method. if we can specify mass flow rate, how can it be?
Old   September 10, 2006, 04:43
Default Re: re:abt vof
Rizwan
if your flow is incompressible, since density is contant, use velocity inlet BC. hope this helps. i used VOF for oil water flows to track interface and it was helpful for me. Regards
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
Question:Considerations about the evaporation in VOF dokeun FLUENT 10 February 24, 2011 20:47
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 10:57
ATTENTION!! Validty of Fluent's VOF?? ozgur FLUENT 1 February 18, 2004 11:59
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
