error message when compiling the udf
hi all
when i compiling this msg will shown the system cannot find the path you specified.any one guess what may be the reason? but the file was saves in the same directory. advance thanks |
Re: error message when compiling the udf
It depends on where you compile udf... linux or windows? if it is windows you have to install visual studio....
hi i have c programming,i just use the tutorial that given by one of the cfd user.when i compile this program using c,it shows some 25 error.plz any one have compiled totorial in the area of boiling and consdensation.
thanks in advance |
ok.... have you tried to install visual studio on windows? otherwise it is not able to do "make" ....
hi recardo
now i installed the visiual studio,when i compile this message is appeared"unable to locate DLL" the dynamic link library fl6216s.exe could not found in specified path. plz help me thank u |
ok....... I suggest to unistall fluent, install fluent, set the environment variables (start---fluent---fluent---set environmental variables).
Your UDF is written in C? |
ooooooooooha its working thank u soo much ricardo
