significant gap between the wall and moving piston
Old   August 28, 2006, 05:23
Default significant gap between the wall and moving piston
Sha
Hi, In my problam, There is a cylinder and a psiton that creates gaps in both sides, More precisely, There are three walls - that look like this : |_| and a rigid wall(piston) that moves in sin way up and down ,The piston is narrow in a way that two gaps are created in the left and right sides.
I am only intersting in the flow inside the cylinder, The area over the piston is not intersting. I will totaly appriciate detailed explantion for the soultion of this problam. I realy dont have a clue, I read a little about dynamic mesh and i preffer not to deal with UDF(its sounds complicated)
Thanks a lot in advance, Sha.
Old   August 28, 2006, 13:21
Default Re: significant gap between the wall and moving pi
Ahmed
Look the tutorial for a sliding mesh
Old   August 28, 2006, 15:24
benjo
hi, i have the same problam, anyone can advice a simple way to solve this problam ?
Old   September 20, 2006, 06:08
Default how can modeling a moving wall?
Nikolaos
My model consists of a box where in the top of it and in the bottom bordering with a moving wall. between the box and the moving wall exist air. the moving wall moves in the x-axis with 10 m/sec. how can give the boundary conditions to the moving wall?
please help me!!!
Old   September 20, 2006, 11:15
Default Re: how can modeling a moving wall?
Albert F.
As I know you need to specify a velocity in the wall you want. You can do this by changing a couple of things in the momentum panel of the wall:
Wall motion: Moving wall
Motion: Relative to adjacent wall (if adjacent cell is air for exemple)
Shear Stress: here there are two options no slip or specify shear. I usually specify shear stress with 0 constant stress on both directions (X an Y) to achieve a velocity profile where the velocity is 0 near the wall.
If you have defined the shape as a solid you have to impose a moving reference frame on bc panel.
I don't know If I have explained it clearly, any doubt ask me for more info. Hope it helps.
gap between the wall and moving piston Nan CFX 11 September 9, 2019 17:39
UDF for slip and moving wall lichun Dong FLUENT 3 March 26, 2014 04:37
stationary wall vs. moving wall user0314 FLUENT 0 August 26, 2011 09:42
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 11:33
