September 19, 2006, 07:24 |
Converging then Diverging Residuals???
I was wondering if anyone has ever had any experience with residuals that intially start to converge and then after several iterations (i.e. 25,000+), they start to diverege??? I am working with the Reynolds Stress Model and I have decent convergence (1e-05) on everything except continuity (1e-2). In trying to get continuity to converge I let the simulation run and now at 25,000+ iterations I'm noticing that my Reynolds stresses, y-velocity, k and epsilon are starting to diverge slowly...Is the simulation adjusting itself in order to get the continuity to converge??? If it helps at all I'm simulating a flat plate boundary layer with super super fine mesh and low freestream intensity (0.2%). Any ideas??? Thanks so much, Erika |
September 19, 2006, 10:20 |
Re: Converging then Diverging Residuals???
It is normal dont worry
September 19, 2006, 10:24 |
So then should I allow the solution to progress??? Will it eventually converge???
September 19, 2006, 10:27 |
yes. But not in absolute terms. It may start fluactuating between some value i.e diverging and converging. check the mass flow balance(it is ur gloval convergence)
September 19, 2006, 10:30 |
Thanks for your help!
September 19, 2006, 10:32 |
wats ur msn or yahoo id?
September 19, 2006, 10:35 |
I don't have one.
September 19, 2006, 10:37 |
which type of flow u r working on
September 19, 2006, 10:45 |
#9 |
I'm simulating a boundary layer experiment that was conducted in a wind tunnel with very low free stream turbulence intensity (0.02%). I'm actually trying to duplicate the turbulence intensity curves that Klebanoff published in his experiment from 1955 (Characteristics of Turbulence in a Boundary layer with Zero Pressure Gradient).
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
Converging Diverging Nozzle in OpenFOAM | danishdude | OpenFOAM Running, Solving & CFD | 1 | September 15, 2012 00:12 |
k and epsilon residuals not converging | NISHIKANT TAMRAKAR | FLUENT | 9 | October 11, 2011 10:47 |
Converging the Turbulent Equation Residuals | Josh | CFX | 0 | November 29, 2010 19:02 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
