parameters to select a solver for a model in gambt
Old   September 18, 2006, 02:16
Default parameters to select a solver for a model in gambt
abid
hello to every one ,
what solver type should be used for a 3D model in gambit. what are the parameters which helps us to define the right one .
Old   September 18, 2006, 05:51
Default Re: parameters to select a solver for a model in g
sam
fluent 5/6
Old   September 20, 2006, 13:07
mohammad
It depends on the solvers you have. If you can access Fluent 5/6, that is ok.
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Blow of compressible solver while using K-epsilon model in openfoam Amit Mathur OpenFOAM 16 October 6, 2013 11:09
Turbulence model parameters Vidya Raja FLUENT 2 October 6, 2006 13:38
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
