initalizing error
Old   September 20, 2006, 08:43
Default initalizing error
seeta
hi all, i am getting error when i am initializing my inlet velocity value the error : invalid flonum error object:nanq can anybody expalin me why it is comming and how i can rectify this error
Old   September 20, 2006, 09:31
Default Re: initalizing error
Jason
This is typically related to a poor mech. Do Grid->Check to see if there are any errors.
If that's not the problem, post more details of your setup.
Hope this helps, and good luck, Jason
Old   September 21, 2006, 01:09
seeta
hi i have done the grid check but i did not get any problem with that.my grid details are min Volumeis 2.77e-11 and maximum volume 2.407e-9 and total volume 3.35e-4 min face area is 8.8e-8 and max. face area 3.55e-6 aspect ratio is 1 to 20 equi skew size is 0 to 1 hope this information will help u to find out the error in my grid
Old   September 21, 2006, 09:46
Jason
equi skew of 1 will cause the problem... go back to Gambit (or whatever meshing software you used) and double check the equi skew there. The lower the better, but I don't remember being able to run a mesh with a skew higher than .97 (when I mesh with tet, my goal is typically .8 maximum and I'm willing to accept a few cells around .92 to .95 depending on where in the model they occur... if it's an area of high gradient, then I won't accept it, but if it's in a region of separated flow or away from the geometry of interest, then I accept it).
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
