Home > Forums > FLUENT
Fluent 64 bit on FC5 (AMD Opteron)
Old   September 22, 2006, 13:46
Default Fluent 64 bit on FC5 (AMD Opteron)
saa_pondy
Dear All,
I get the following error while running Fluent 6.2.16 in a AMD 64 bit machine with FC5 64 bit OS:
/usr/Fluent.Inc/bin/fluent: line 3600: unexpected EOF while looking for matching ``' /usr/Fluent.Inc/bin/fluent: line 3878: syntax error: unexpected end of file
Is this has already been discussed in the forum? If not please advise.
Thanks.
saa_pondy.
Old   September 24, 2006, 21:01
Default Re: Fluent 64 bit on FC5 (AMD Opteron)
Raj Kiran Grandhi
Downgrade bash to version 2.05
Old   September 25, 2006, 03:28
astro1
Can it work with bash 3.0 ?
Old   September 25, 2006, 07:43
saa_pondy
I downgraded to bash 3.0, subsequently I get the following:
[root@nrml ~]# FLUENT_ARCH=lnamd64; export FLUENT_ARCH [root@nrml ~]# /root/Fluent.Inc/bin/fluent & [1] 12115 [root@nrml ~]# sort: invalid option -- 2 Try `sort --help' for more information. Error: program /root/Fluent.Inc/fluent6.2.16/cortex/lnamd64/ does not exist. The versions available in /root/Fluent.Inc/fluent6.2.16/lnamd64 are: 2d 2ddp_host 2d_host 3d 3ddp_host 3d_host 2ddp 2ddp_node 2d_node 3ddp 3ddp_node 3d_node
Please advise.
Thanks.
Old   September 25, 2006, 15:28
astro1
Did you success with bash 2.05?
Old   September 26, 2006, 15:01
astro1
I get the same problems and I dont know what to do.
Old   September 26, 2006, 21:01
Raj Kiran Grandhi
Try bash 2.05.
Old   September 27, 2006, 13:24
astro1
I tried and it didn't work. Which setup do you use for running your Fluent ?
Thank you.
Old   October 6, 2006, 11:44
yizhou
You should download and install the Critical Patch 3 from site: http://www.fluentusers.com/fsdc/fsdc...f1=1&f2=0&f3=0
You will find out the patch after selecting the platform and click on Show Optional Packages.
Yizhou
Thread Tools
Trackbacks are On
AMD Opteron 2389 vs. Xeon W5580 soni7007 Hardware 1 May 3, 2009 17:42
Fluent gives libc error on 64 bit AMD Fedora 9 Kumar FLUENT 3 October 7, 2008 12:52
Fluent and AMD x2 D_Lichu FLUENT 2 September 21, 2008 17:38
FLUENT on Dual AMD AthlonMP system? Arild FLUENT 2 January 10, 2002 05:12
Running Fluent on Linux AMD machine David Reinbold FLUENT 5 September 21, 2001 17:08
