Fluent error on FC4 64 bit (lnamd64 platform) |
September 23, 2006, 07:03 |
I would appreciate if the following can be figured out for lnamd64 fluent 6.2 installation on fc4 64 bit.
------------------------------------------------------------- [root@localhost ~]# /usr/Fluent.Inc/bin/fluent & [1] 3079 [root@localhost ~]# /usr/Fluent.Inc/fluent6.2.16/cortex/lnamd64/cortex.3.6.6 -f fluent (fluent " -path/usr/Fluent.Inc") /usr/Fluent.Inc/fluent6.2.16/cortex/lnamd64/cortex.3.6.6: error while loading shared libraries: /usr/Fluent.Inc/lib/lnamd64/libhoops920.so: cannot restore segment prot after reloc: Permission denied ------------------------------------------------------------- Thanks in advance. saa_pondy. |
September 24, 2006, 13:20 |
Re: Fluent error on FC4 64 bit (lnamd64 platform)
The only advice I can give you about Fluent 6.2.16 on Fedora Core 4 for AMD64, is that when I tried it, it didn't work either. I "solved" the problem by just making sure that I installed ALL packages from the FC4 distribution. It means that you end up with loads of stuff you don't want or need, but you do get all the libraries required by Fluent.
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
FLUENT license on LINUX platform.. | Jim Clancy | FLUENT | 4 | May 8, 2002 02:01 |
FLUENT, 64-bit platform & IRIX | jim clancy | FLUENT | 1 | January 31, 2002 17:32 |
Fluent Uninstall_unix platform | Theju | FLUENT | 0 | October 5, 2001 09:02 |
