UDF for time stepping
Old   September 25, 2006, 09:41
Default UDF for time stepping
fulvio
I should impose variable time stepping that would works like follow:
if(flow_time <= 0.15) {
(timestep = 0.001); } else if(flow_time > 0.15 && flow_time <= 0.3) {
(timestep = 0.0005); }
but I do not know which is the correct way to do that using DEFINE(I have used UDF for velocity inlet and pressure but never for time stepping) thank you in advance
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
