iterative running of two sub models
Old   September 27, 2006, 04:30
Default iterative running of two sub models
Babu
Hi all:
I have a huge 3D (360 deg.) fluid domain. I got strong necessity to simplify the domain by chunking it to two sub domains and also with two different sector angles and run both iteratively till I derive converged solution. To avoid huge mesh size. I got only the inlet and outlet pressures (BCs) of the overall fluid domain. The bi-sectioning of the model is planned to have it at a location where gradients are very less.
The process I would like to implement to this problem is as follows
1. Run Domain-1 separately with pressure BCs (assuming exit pressure BC). 2. Mass outflow from this run is captured and supplied as inlet boundary condition to Domain-2 3. Run Domain-2 with this mass inlet and given exit pressure BC. 4. Extract inlet static pressure from second run and supply back that pressure to the first case. 5. Keep iterating two domains till results across the interface converge.
Is it a right way to do? Is there any other existing process behind?
If this is a correct, how can I map one 3D sector results to another, when they are different?
Please let me know.
Thanks in advance Babu
Old   September 27, 2006, 08:40
Default Re: iterative running of two sub models
Chandra Murthy
i have done similar kind of problem. you did not mentioned the overall flow behavior(compressible/incompressible). anyways, there are two points here. 1) if the plane where you are seperating two domains is experiencing supersonic flow, definitely you can implement the procedure mentioned by you using profile boundary conditions.And also, you need not iterate between the two solutions for transfer of bc's. 2) if it is subsonic flow the upstream effects will matter for the accuracy of the solution. obviously you should not implement the seperation of domains.
Comparing spallart-allmaras, k-epsilon, k-omega models glex1308 Main CFD Forum 0 March 30, 2011 14:45
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 21:31
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 04:18
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 03:21
star is not running the simulation in windows Arnab Siemens 1 August 2, 2004 02:40
