Home > Forums > FLUENT
need suggestion
Old   September 26, 2006, 18:58
Default need suggestion
I am trying to solve a case of circular air jet emanating into a cylindrical vessel filled with air ie, under atmospheric pressure. I am trying to solve a 2D axisymmetric case. so my jet radius is 0.0005m (0.5mm) and the domain is 0.1mx0.1m (100mmx100mm). I am giving a parabolic velocity profile with a max velocity of 30m/s at the velocity inlet which will be in laminar range. So my question is will this case come under micrometer scale flow dynamics and will the Fluent's default solver be able to solve this problem. And also,If I can solve this case using FLUENT's default solver, what kind of mesh you will suggest me so that it wont make up several hundred thousands or millions of nodes and I will be able to solve using an ordinary computer.
Old   September 27, 2006, 11:07
Default Re: need suggestion
Please someone correct me if Iīm wrong, but I believe that you can mesh the problem as if it were a normal problem, only you have to put some ceros before the size number I think that you donīt need a huge number of elements.
Hope this helps.
Old   September 27, 2006, 16:49
Thanks Seldon, But,Consider the size of the velocity inlet (jet radius) compare it with the domain size. I have to give a parabolic velocity profile. so, calculate and tell me how many nodes I gonna need at the velocity inlet and if so estimate the number of elements in the entire domain.
Thread Tools
Trackbacks are On
suggestion for thermophysicalproperties for high temperature buoyant flow braennstroem OpenFOAM Running, Solving & CFD 0 March 21, 2011 15:06
any suggestion about method to use? cnmm Main CFD Forum 0 May 28, 2009 23:13
error suggestion llnudt FLUENT 1 November 14, 2006 02:48
Suggestion please newbie FLUENT 0 October 29, 2001 22:28
need suggestion on temperature simulation Bin Li CFX 4 June 23, 2000 02:35
