Home > Forums > FLUENT
Regarding about References values
Old   September 27, 2006, 11:01
Default Regarding about References values
HSeldon
Hi folks,
Im working with a whole airplane and Im having some problems to make clear this: Im wanting to get the CL and CD of the plane. So, what reference values should I put? And, in the force monitors, I have to select all the surfaces that conform the airplane, right?
Thanks in advance.
Old   September 27, 2006, 11:22
Default Re: Regarding about References values
Jason
You should have a reference that you're comparing to (another airplane for example). Use a similar reference area as what you're comparing to (i.e. if your baseline is another airplane that uses the wing area for it's reference, then you should be using your wing area as your reference). The planform of the wings is a common reference area, but again, make sure you're using the same thing as what your comparing to, otherwise the numbers are useless.
Yes, you have to select all of the surfaces.
Hope this helps, and good luck, Jason
Old   September 27, 2006, 16:36
HSeldon
Very clear Jason, thanks a lot!
Thread Tools
Trackbacks are On
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 28 May 28, 2015 13:37
Interpolation values in nodes and cells mrestrepo30 FLUENT 0 April 27, 2010 09:20
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
