Pressure outflow w/ species; mass frac. required? |
September 29, 2006, 14:15 |
Hi all,
I'm trying to run a standard simulation of gas uptake along a tube, and I've found that when using standard outflow, I only need to provide flow weighting, but the solver doesn't always converge well. When using a pressure outflow, which gives me the needed flow convergence, I have to also specify a mass fraction at the outlet-- is there any way around this, to deactivate that boundary condition requirement, so that I can let the solver determine the outlet mass fraction? The very nature of my simulation is to determine the outlet mass fraction; it is not a value I can even guess offhand. Thanks in advance. |
September 29, 2006, 19:29 |
Re: Pressure outflow w/ species; mass frac. requir
Try to use targeted mass flow option with pressure outlet bc
September 29, 2006, 23:08 |
The outlet mass fraction is not what you consider it to be. If there is any reverse flow (flow enters thru outlet) then that occurs with the mass fraction you set. This setting should be realistic. If component X does not enter from inlet 0 is the logical setting for that component. Thus, solver is doing the job and you need not "deactivate" any setting. Swarup. |
Combination of mass flow inlet and pressure inlet boundaries | MrStuebb | Main CFD Forum | 0 | January 6, 2011 09:59 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Mass & Pressure Boundaries | kantipudi | FLUENT | 0 | February 5, 2009 12:38 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
