-   -   gambit journal for run a journal? (http://www.cfd-online.com/Forums/fluent/42439-gambit-journal-run-journal.html)
Ralf Schmidt October 2, 2006 12:45
Hi!
is there a journal command, to open other journals?? When I use the line:
/ Starting readfile /home/rschmidt/journal.jou
nothing happens.
The .jou file, that is created during every gambit session has no commands for opening a journal in it, it starts right away with the commands from the journal that has been opened.
Any idea??
Ralf
Abhijeet Karnik October 2, 2006 14:53
Re: gambit journal for run a journal?
Ralf,
I was trying to do something similar in the fluent journal file and found out that you cannot open a journal from within a journal. But you can continue writing to a journal file that is being executed.
I do not know if the same holds true with gambit.
Regards Abhijeet
zxaar October 2, 2006 16:52
copy that journal file into this one and make a bigger one and execute, it shall work (temp fix)
Edward! May 25, 2010 14:41
run a journal to generate a mesh for a 2D profile
Hi everyone
I want to schedule a mesh in gambit for a profile in 2D but I dont Know how to start someone could recommend me some book or suggestions to run a journal please :(
Best Regards
