October 3, 2006, 10:07 |
invalid command error
Hi everybody, I am running Fluent in the batch mode using the following script and I am getting 'invalid command' error right after it reads the file. However, it works when I type it in the interactive mode. I used to run this script with exactly the same model with slightly different geometry.
Anyone has an idea what the problem might be? Thankssss a lot. Ahmet /file/rc 8-30-60-060929-00.cas /define/boundary-conditions/velocity-inlet 4 n n y y n 6.69 y y n , n , /solve/initialize/compute-defaults/velocity-inlet 4 /solve/initialize/initialize-flow /solve/iterate 250 wd 8-30-60-060929-09.dat |
December 10, 2013, 05:18 |
Invalid Command Error
I use Fluent on Windows and this error appears when i save journal file in UTF-8. If I use ANSI (default encoding in MS Notepad), everything is OK.
ANSI encoding Code:
Reading journal file C:\path\scale.jou... > mesh/scale 0.001 0.001 0.001 Code:
Reading journal file C:\path\scale.jou... > mesh/sinvalid command [mesh] cale 0.001 0.001 0.001 |
April 24, 2021, 12:17 |
still valid solution
milan swart
This 'solution' is still valid in Fluent 2021R1.
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 12:50 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 21:23 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
