October 9, 2006, 08:51 |
UDF for parallel computation
Hi
I tried to hook UDF function in parallel mode. It has been successfully compiled for parallel and tested on multiprocessor windows pc. The problem occured when I tried to hook this UDF on cluster machine. Fluent printed that udf cannot be opened and hanged. Thank you. |
October 9, 2006, 09:23 |
Re: UDF for parallel computation
Hello Stanislav Kraev,
I'm having the same problem although running on a linux cluster. I too would like to know the answer to this question. Regards |
October 9, 2006, 21:23 |
I think you both have some problems with the code. Sometimes you need to convert your code from dos to linux. convert your code like "dos2linux". I hope it will work.
October 10, 2006, 03:12 |
I have only worked in linux environment. Any other suggestions?
Display Modes | |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
Error in compiling UDF for computation of space charge density | greensociety | FLUENT | 1 | July 21, 2009 02:29 |
UDF moment ( torque ) computation | aja | FLUENT | 1 | March 28, 2007 16:55 |
