movin wall
Old   October 12, 2006, 04:10
Default movin wall
Rashad
Hello I am using moving wall boundary condition. Problem is I have four wall of a plate when i give velocity in the Y direction to the walls. It shows the velocity y component at vertical walls but did not show any velocity at the other two walls. Althouhg it shows the velocity magnitude in all the walls. It is strange that if it shows the velocity magnitude it should also shows the y component of the velocity as their is zero velocity in the x direction. IWhat i am doing wrong is it my interpretion or i am doing some bug. Thanks in advance Rashad
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
