EULER PARTICULATE DEPOSITION
I'm trying to simulate how particulate and PM10 can settle in a urban canyon. I don't how verify if deposition occurs in my eulerian multiphase model. Is there a procedure to read the mass rate toward the walls? I'm using fluent 6.1.22 with k-e turbulence model and mixture multiphase model. Thank you in advance to everybody want help me :)
Mirko |
Re: EULER PARTICULATE DEPOSITION
Hi Mirko,
you have an interesting problem. I can't answer your question right away, but maybe you could describe your problem more in detail to me. Do you have a paper puplished where i could read through? If possible you could try Descrete element method, because you can track your particles and therefore, estimate there deposition. Much luck Best regards Stefan |
