-   -   problems with VERY simple mesh (http://www.cfd-online.com/Forums/fluent/42583-problems-very-simple-mesh.html)
Ralf Schmidt October 17, 2006 01:21
Hi!
I have a very simple mesh in gambit (2D, about 5000 tri cells, only 10 cells with an equiSize Skew higer than 0.22).
Now, exporting to and importing in Fluent is no problem. Performing a grid check is ok as well. Now, I turned the solver to axissymmetric and activate k-epsilon modell. After that, a new grid chek failed:
WARNING: non-positive volumes exist.
Waht happend???
ANY idea??
Ralf
mAx October 17, 2006 01:24
Re: problems with VERY simple mesh
check if your revolution axis is absolute coincident with your x-axis
Claud October 17, 2006 01:35
and it should be only in positive direction on both axis.
Ralf Schmidt October 17, 2006 01:37
Hi, thx for answer...
that might be the problem, but: First, I had the axis BC parallel to the y-axis, now it is coincident to the x-axis. But the problem still appears when i turn on the axis-symmetric solver.
Ralf
Ralf Schmidt October 17, 2006 01:45
it is, but that doen't help...
mAx October 17, 2006 02:33
check if the revolution axis lie exactly on the x-axis. a small gap about 1e-3 under the x-axis will crash the grid check
Ralf Schmidt October 17, 2006 05:54
problem solved!
Hi!
in the domain extents it is visible: the y domain starts from -1.2 e-14 - so there are some nodes below the x-axis!!
I solved the problem - editing the msh file: exchanging all y values below 0 to 0. Another way: translating the whole mesh in y-direction.
It works fine now... but why does fluent (or gambit) produces that problem???
Ralf
sach October 17, 2006 07:21
hey have you checked right handed ness or left handed ness problem
