problems with VERY simple mesh
Old   October 17, 2006, 01:21
Default problems with VERY simple mesh
Ralf Schmidt
Hi!
I have a very simple mesh in gambit (2D, about 5000 tri cells, only 10 cells with an equiSize Skew higer than 0.22).
Now, exporting to and importing in Fluent is no problem. Performing a grid check is ok as well. Now, I turned the solver to axissymmetric and activate k-epsilon modell. After that, a new grid chek failed:
WARNING: non-positive volumes exist.
Waht happend???
ANY idea??
Ralf
Old   October 17, 2006, 01:24
Default Re: problems with VERY simple mesh
mAx
check if your revolution axis is absolute coincident with your x-axis
Old   October 17, 2006, 01:35
Claud
and it should be only in positive direction on both axis.
Old   October 17, 2006, 01:37
Ralf Schmidt
Hi, thx for answer...
that might be the problem, but: First, I had the axis BC parallel to the y-axis, now it is coincident to the x-axis. But the problem still appears when i turn on the axis-symmetric solver.
Ralf
Old   October 17, 2006, 01:45
Ralf Schmidt
it is, but that doen't help...
Old   October 17, 2006, 02:33
mAx
check if the revolution axis lie exactly on the x-axis. a small gap about 1e-3 under the x-axis will crash the grid check
Old   October 17, 2006, 05:54
Default problem solved!
Ralf Schmidt
Hi!
in the domain extents it is visible: the y domain starts from -1.2 e-14 - so there are some nodes below the x-axis!!
I solved the problem - editing the msh file: exchanging all y values below 0 to 0. Another way: translating the whole mesh in y-direction.
It works fine now... but why does fluent (or gambit) produces that problem???
Ralf
Old   October 17, 2006, 07:21
sach
hey have you checked right handed ness or left handed ness problem
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Using a hybrid mesh for a simple pipe Udio_NT ANSYS Meshing & Geometry 17 October 18, 2012 14:42
[GAMBIT] Error on simple mesh Rich1979 ANSYS Meshing & Geometry 3 August 16, 2010 05:21
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
