-   FLUENT (
-   -   Thrust and torque of a propeller (
Alex H October 17, 2006 07:15
What is the easiest or most common method of determing the thrust and torque for a 3D propeller (my first CFD 3D experience). This was modelled using a rotating reference frame and periodic boundaries.
Thanks in advance,
Jason October 17, 2006 08:07
Re: Thrust and torque of a propeller
That will output both the raw force and the coefficient. If you're working with coefficients, make sure you've set your reference values in Report->Reference Values.
Hope this helps, and good luck, Jason
881111135 June 29, 2016 15:17
excuse me!!!
what is the right refference area to get the right trust coeficient in proppelers?
scipy July 1, 2016 17:00
Seems it's just the disc area described by the propeller. I know that's the case for helicopter rotors...
