Home > Forums > FLUENT
How can I do this??
Old   October 19, 2006, 21:10
Default How can I do this??
akr
Hi everyone,
I want to know and show the part of which the velocity is below certain value in graphics window. I have done the calculation in 3D, so I can know the velocity distribution in the domain. What I want to do is to show the part of below the certain velocity in the graphics window. And I want to calculate the volume ratio of low velocity part to whole apparatus.
Could you tell me how to do this, please?
Thanks, AKR
Old   October 20, 2006, 01:36
Default Re: How can I do this??
Gernot
to visualise the areas with low velocity you can creat isosurfaces ( but every surface with just 1 velocity ). So if you creat for example 10 isosurfaces with lower than certain velocity you can have a look where these areas are. There is also the possibility to mark the areas with lower velocitys in the adapt / iso-value panel but i`m not sure if there is a possibility to calculate the volume ratio out of this (maybe you can seperate your interior with the marked volume but i never tried that).
Old   October 20, 2006, 05:10
akr
Thanks, Gernot. Maybe you are right. If I can separate the low velocity zone, I can know which cells have low velocity. And then I can calculate the volume of cells which have low velocity. It will be good!! But I hope there is more simple way to get this. Does anybody know how to do this?
Thanks, AKR
Old   October 23, 2006, 00:18
nayiwan
not sure if i got what you mean, try this
Display->vectors click autorange and then input the valued you want to display in the panel, where min & max indicates, and click display
Thread Tools
Trackbacks are On
