-   -   Need help with mixing two liquids (http://www.cfd-online.com/Forums/fluent/42657-need-help-mixing-two-liquids.html)
Albert October 23, 2006 09:10
I'm modelling mixer for two liquids: water and oil. Solver is steady, segregated, euler multiphase. Primary phase - oil, secondary - water, size - 1 mm. Mesh is tetarhedral with 1 mm step. Two liquids enter from pressure inlets (different pressures, phase fractions for sec phase are 0 and 1 respectively) and leave from pressure outlet. Solution converges very well, but when i postprocess results I dont see water fraction in outlet steram. Flux report shows reasonable amount of water and oil. Tried both steady/unstedy, mixture/euler no results.
Any ideas for solving this problem?
PS Fluent 6.1.18
Lalal October 23, 2006 15:33
Re: Need help with mixing two liquids
do not use tetraedral meshes for this!!!!
Michael B October 24, 2006 01:47
There must be a better suggestion than that...
Ryan October 27, 2006 01:18
Can you give me one good reason for usig multiphase model.
Ryan
Albert October 27, 2006 11:17
Why not? what is the problem with tetrahedral, it is the easiest way to mesh. It is not that I wont try hexahedral, just want to know the reason. And thanks for the answer, will report on results withdifferent mesh.
Albert October 27, 2006 11:22
Khm, didnt get the idea. Is there any alternative? If there is what is it, and thanks for help!
Ryan October 28, 2006 03:52
please go through the chemical species tutorial for defining additional scalars.
It tells u how to mix methane with air. Your problem is something similar to this.
Should be a good start.
Good luck
Ryan
Albert October 28, 2006 07:34
Thanks, I will look at that!
