Different case files activate ALE Eq.
Old   November 2, 2006, 14:39
Default Different case files activate ALE Eq.
kevin
Hi, everybody. In the unsteady case, if coordinates (x,y,z) of nodes are changed at every time step, then activate arbitary lagrange equation (ALE) is activated? The fluent has dynamic zone which automatically is changed by user defined grid motion, then it activates ALE. For conservation of geometry law, it is important. However, without defining dynamic zone, just changing the coordinates of case files, I wonder if fluent calculate the effect of grid movement.
Thank you
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
How to read or write case by commands during simulation with Fluent lzgwhy FLUENT 4 April 20, 2011 23:02
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
Are Case and Data files enough? Zhengcai Ye FLUENT 6 January 8, 2004 05:02
