gambit warning
Hello All,
While meshing my model in gambit, i am getting a warning, that is "Connected geometry may be imprinted by the requested operation". Gambit gives this warning when i am deviding a volume in to two sub volumes with SPLIT operation. Can any one has an idea, hwat the warning corresponds to??? will it give any problem afterwards. Thanks in advance. Madhukar |
Re: gambit warning
d'ont worry, this warning is not problem because when you split the total(original) volume in to two or three... sub volumes, the total(original) volume disappears, then gambit transmits this warning . it is logical because you have used the split operation this warning will create too when you unit volumes,substract,... best regards
