October 31, 2006, 03:58 |
Creating Curved Lines/Rakes
Hi all
I am currently having some trouble post processing. I have modelled a segment of a rotating component using a single rotating reference frame. I wish to create an arc of a given radius using the line/rake tool in order to generate XY plots using the curve length function for the x axis. However I have been unable to do so using the line rake command. Any help that could be offered regarding this problem would be much appreciated Please see: http://i136.photobucket.com/albums/q...ndayz/Help.jpg for an example of the type of line I wish to create. Thanks Ed |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 07:59 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 03:02 |
drawing curved line,plotting skin friction lines | Alex | FLUENT | 1 | November 17, 2005 07:16 |
