Problem of DEFINE_DPM_OUTPUT
Old   November 12, 2006, 23:46
Default Problem of DEFINE_DPM_OUTPUT
akr
Hi all,
I want to write a UDF to obtain data about which particles escaped. I am using file as injection type. And I have to inject many particles. So I am thinking about using DEFINE_DPM_OUTPUT. In udf manual, there is a example. But I can not understand it. Does anyone know how to write this kind of udf??
Thanks, AKR
Old   November 13, 2006, 12:18
Default Re: Problem of DEFINE_DPM_OUTPUT
Allan Walsh
See comment to your earlier post, below.
Old   November 13, 2006, 22:42
akr
Hi Allan,
I saw your comment. I am thinking about writing UDF. Maybe DEFINE_ON_DEMAND is also good. What I want to know is how to access the particle ID. I saw DPM variables in udf manual. But I could not find about particle ID.
Do you know how to access the particle ID?
Regards, AKR
Old   November 14, 2006, 13:19
Allan Walsh
From your description of what you are trying to do, DEFINE_ON_DEMAND is not the right UDF.
To find particle variables, first look in the dpm.h header file. Then, you may need to look a bit deeper in some of the other header files.
Alternatively, you could create your own variable and then increment it as you loop through the particles.
Good luck.
Old   November 14, 2006, 21:13
akr
Hi Allan,
Thank you very much. I will try your suggestion. I hope I can do that. Again, thanks.
AKR
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
