yplus=o???????,in wall function,kepsilon,need help
Old   October 15, 2006, 02:49
Default yplus=o???????,in wall function,kepsilon,need help
ramy
flow of water,steady and isothermal case,kepsilon,wall function:standard yplus =o------ whats the problem? best regards
Old   October 15, 2006, 03:19
Default Re: yplus=o???????,in wall function,kepsilon,need
sam
is there any sepration in the region of y plus 0?
Old   October 15, 2006, 03:27
ramy
I don't understand your question
Old   October 15, 2006, 06:17
ice
when did you check the y+, before the Iteration or after it?
Old   October 15, 2006, 10:20
ramy
after converging of results(after iteration)
Old   October 15, 2006, 12:46
Ralf Schmidt
Hi!
Are you sure, that it is = 0 ??? it might be so small, that the resolution in the plot window make it appears like 0.
Maybe, you are not plotting yplus on a wall - BUT it is only defined for a wall!! In other word: are u sure, that the bondary you used for plotting it a wall??
Another reason might be the plot direction. If you have a wall that is parallel to x-axis, and you plot on y-axis, Fluent returnes 0.
Hope, it helps - I don't see any other explenation...
Ralf
Old   October 17, 2006, 00:54
sam
y plus is calculated on the basis of shear stress. in the region of sepration therefore yplus(for wall fuction) = 0 . therefore i asked that are u reporting y plus 0 for the region of sepration of attached flow. hope u understand my point
regards sam
Old   November 2, 2006, 06:02
Default convergence problem while using pressure inputs
Ashok kumar
I get convergence problem for incompressible flow when i use boundary inputs both in terms of pressure. I even reduced the relaxation to 0.1 for all the terms still i get the same problem. Anyone help me on this.
Old   November 3, 2006, 13:58
Default Re: convergence problem while using pressure input
babak
maybe you have reversed flow problem. check your operating pressure
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
