-   -   importing gridgen msh into fluent/gambit (http://www.cfd-online.com/Forums/fluent/42745-importing-gridgen-msh-into-fluent-gambit.html)
CH November 2, 2006 22:01
hello,
may i know how can i import gridgen mesh into fluent/gambit? what type of file format must i use to save in gridgen to achieve this?
thank you.
myron November 3, 2006 08:17
Re: importing gridgen msh into fluent/gambit
From GridGen you should be able to save a Fluent .cas file.
John Chawner November 5, 2006 13:21
Goto the Analysis Software menu. Set your flow solver to Fluent. Then use the Export Analysis Data command. It will write a .cas file.
Hope this helps.
CH November 5, 2006 19:55
ok, got it. but the step i'm missing is actually defining the block. before that is done, the export to analysis data command is greyed ot.
John Chawner November 5, 2006 22:27
I can't tell from your reply whether you figured out how to create blocks or not. So just in case... Blocks Create Assemble Faces If the grid is structured, select the domains that comprise each of the 6 faces, face by face. If the grid is unstructured, select the domains that comprise the face. If the overall grid is 2D (as set in the ASW menu), you'll make just one face for the structured grid.
