Home > Forums > FLUENT
UDF problem
Old   November 3, 2006, 15:39
Default UDF problem
Marijo
How can I print a value that is calculated in the UDF? Something with print command in the UDF?
Thank you.
Old   November 3, 2006, 16:43
Default Re: UDF problem
C. H.
print in file or on screen? There are of course other and maybe better possibilities but within my UDF's it works.
screen: Message0("Your Text %20.13e \n", Variable); %20.13e is the format for the value that would be written at this place. 20 is the whole length and 13 is the amount of numbers after . and e means it is written in 3.0000000000000e-03 for example. You can also use %f for a float number or %i for an integer. \n is End of line
file: File *pointer_to_file; pointer_to_file = fopen("test.dat", "w"); fprintf(pointer_to_file, "Text in file %20.13e \n", Variable); fclose(pointer_to_file);
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
