GAMBIT Macros
Old   November 6, 2006, 14:48
Default GAMBIT Macros
VikrantCA
Hello, I have some heat exchanger models that are stored in a file in a proprietary format. I want to convert this heat exchanger into a GAMBIT file to later run with Fluent. I wrote a c++ program that will spit out GAMBIT journal commands/code. Is there an efficient way of doing this ? In GAMBIT journal - how do I access a particular face of a brick ?
thank you. vikrantca
Old   November 7, 2006, 16:00
Default Re: GAMBIT Macros
Azamat
I did this before. You must record the macro from gambt first and generate the "journal file" line by line. Then you can replace some key numbers by variable name that can be replaced by a script (shell script).
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
What are UDF macros C_T_S , C_T_AP,...???? Asghari FLUENT 0 January 28, 2007 10:54
Writing Gambit Macros Johnny FLUENT 0 March 20, 2004 03:10
