natural / free convection in a vertical tube
Old   November 10, 2006, 13:07
Default natural / free convection in a vertical tube
Stephan
I'm trying to model natural convection in a vertical tube with a closed warm end and an open cold end (including and excluding axial heat flux in the wall). I suffer serious convergence problems. I tried several appoaches: initialysing a velocity profile - upward at the wall, downward in the centre of the pipe; modelling only 45 degrees of the pipe and periodic boundary conditions; varying the temperature difference between upper and lower bc. so far no physically reasonable results. has anybody some experience in this field or some hints?
Free Stream Temperature in natural convection problem tomcatbobby FLUENT 2 January 27, 2011 05:41
free / natural convection in a vertical tube/pipe Stephan CFX 3 November 14, 2006 14:48
Natural convection in vertical tube Ravi FLUENT 3 November 7, 2005 10:28
Free convection flow over vertical flat plate Polly Main CFD Forum 1 February 11, 2003 13:25
Free convection flow over vertical flat plate Polly CFX 0 February 11, 2003 02:51
