Delete a macro
Hi everybody!
Just a short question. Does somebody know how to delete a macro from the 'Define Macro' list? I didn't found it.... Thanks a lot! |
Re: Delete a macro
Go to manage micro and delete it then write the *.cas and then start the simulation
Re: Delete a macro
First, thanks a lot for your help.
Could you tell me where I can find 'manage micro' ? I didn't find it. Please help me, and tell me where I can find it. Thanks. |
Re: Delete a macro
Hey in gui it self you can get it follow the way as I sad go to manage micro and delete is that ok or i need to explain in details?
Re: Delete a macro
So that is the problem. When I type "manage micro" in the gui I get the message "invalid command [manage]". So please tell me the path where I can find manage micro.
Thanks a lot! |
Re: Delete a macro
Define>User-Defined>Functions>Manage
Re: Delete a macro
Deleting macros is not easy an requires some scheme programming. The macros are stored in a list called *cx-macros*. You can print this list with (cx-list-macros) from the TUI. To delete a macro from this list you will first need a new scheme funtion which will do this. The defintition of that function (named "rmm" for remove macro) is
(define (rmm a-list i)(if (= i 1)(cdr a-list)(cons (car a-list)(rmm (cdr a-list) (- i 1))))) To delete the second macro from the list type (rmm *cx-macros* 2) This will not yet delete the macro, it will only print out the new list. You can save the new list with (set! *cx-macros* (rmm *cx-macros* 2)) Or if you want to clean the whole macro list just type (set! *cx-macros* (list)) Hope this helps, RoM |
