October 12, 2006, 04:14 |
periodic boundary
when i tried to make periodic boundary rotational for a 30deg sector. it gives error that failed to make periodic . can u help
October 12, 2006, 04:21 |
Re: periodic boundary
Not without more information.
Did you link the meshed edges/faces in gambit for peroidicity? Did you define the preodic conditions as rotational in Fluent? |
October 12, 2006, 06:57 |
Sorry, can I ask you a quastion. Somebody knows how to use a Periodic BC for a SOLID matirial? If it is possible. Thanks in advance.
October 28, 2006, 07:19 |
Hi
The periodic boundary condition can be handle just arround the Z axis . remember that you must use the wall boundary in gambit. also the number of elements must be equal for hx. good luck |
November 16, 2006, 04:48 |
effect of courany no in coupeld slver
hi i need ur help to more about courant no, while iterating "solver trying to decrease courant no temporarily" i kept my courany no as 2 thanking you
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Periodic boundary conditions | happy5jump | FLUENT | 6 | May 3, 2017 00:36 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 02:18 |
Problem with periodic boundary layers | Phil | FLUENT | 15 | October 2, 2000 14:56 |
periodic boundary conditions | Ahmed Abdelwahab | FLUENT | 4 | March 9, 2000 16:36 |
