Home > Forums > FLUENT
LES+Discrete phase
Old   November 23, 2006, 19:03
Default LES+Discrete phase
kk
any idea on how to use the LES+ discrete phase model? I would like to use LES model in modeling a duct pipe. But I am not sure how to use the discrete phase model in a unsteady flow. I have solved the duct flow from time 0e0 to 4e1 seconds and tried to inject particles from the inlet. But I couldn't use 'display' to track the particles. Any idea on that topic is welcome. Thanks in advance. KK
Old   November 29, 2006, 11:06
Default Re: LES+Discrete phase
mm
KK, I am learning to use LES + DPM myself. I noticed that when I do unsteady tracking of particles, FLUENT cannot track the particles at a particular time step. An approach that seem to be more realistic with unsteady tracking is to run your particles at the same time with the fluid. You can try to track the particles with the fluid flow time but give your particle enough time to exit the domain before the flow end time. Once all your particles have exited the domain, you can check how many of those got trapped for the given flow time. I do this in batch mode so that I can get a file saved of all the information. I hope this helps.
Thread Tools
Trackbacks are On
Discrete Phase Model vittal FLUENT 4 October 28, 2014 11:07
continuous and discrete phase coupling in fluids-HELP atmcfd Main CFD Forum 1 December 31, 2009 00:02
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Compatibility LES and Discrete Phase models JADG FLUENT 0 January 22, 2004 21:03
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 08:21
