Vaiable Material properties
Old   November 26, 2006, 08:43
Default Vaiable Material properties
Pialisen
Hai friends,
Can any one explain how to give variable material properties. Actuall i had a block consist of two different materials. How to give material properties seperatly.
Any help please
Old   November 26, 2006, 11:57
Default Re: Vaiable Material properties
vijay
Create two different volume for each block and assign properties. This would be the easiest way.
Old   November 29, 2006, 13:12
Mr.Nantaratn Kananai
Hi Pialisen,
I think when you set material, you set from menu Define/Material... This is a menu for load material from library. If you have 2 materials or more, use menu Define/Boudanry Condition.... then select 'Fluid.1' and click 'Set'. Then, the dialog box will shown you a material that you want to choose for 'Fluid.1', And, I think you should have 2 fluids ,( set by Gambit )
Mr.Nantaratn
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
problem with specifying material properties cavani CFX 5 March 9, 2011 18:36
Temperature-dependent material properties in chtMultiRegionFoam-Solver sebonator OpenFOAM 0 November 15, 2010 08:15
How to add more material properties sarahsun CFX 1 October 27, 2009 07:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
