Vaiable Material properties
Hai friends,
Can any one explain how to give variable material properties. Actuall i had a block consist of two different materials. How to give material properties seperatly. Any help please |
Re: Vaiable Material properties
Create two different volume for each block and assign properties. This would be the easiest way.
Hi Pialisen,
I think when you set material, you set from menu Define/Material... This is a menu for load material from library. If you have 2 materials or more, use menu Define/Boudanry Condition.... then select 'Fluid.1' and click 'Set'. Then, the dialog box will shown you a material that you want to choose for 'Fluid.1', And, I think you should have 2 fluids ,( set by Gambit ) Mr.Nantaratn |
