How to access mean velocity in LES by UDF
Old   December 12, 2006, 11:34
Default How to access mean velocity in LES by UDF
sarah_ron2002
Dear all,
which command I should use to get the mean velocity and RMS in large eddy simulation?
Thanks!
sarah
Old   December 12, 2006, 12:04
Default Re: How to access mean velocity in LES by UDF
hugo
Sarah
First: Solve>Initialize>Reset Statistics This is to reset previous statistics, first time is not necessary
Second: Solve>Iterate There you have to active: Data Sampling for Time Statistics.
Depend your problem you need some time steps without Statistics before run the Data Sampling.
that's all
Good Luck
Old   December 15, 2006, 01:11
selvaganesh
Dear sarah, which command we have to use to get LES in the viscous panel?
Old   December 15, 2006, 17:19
sarah_ron
in 3d case, you could select from GUi. In command line, use viscous/model/large-eddy-simulation in 2d case, it could be activated through a command, search thsi forum. SOrry I forgot the command.
Old   December 15, 2006, 17:21
sarah_ron
Dear hugo,
Thanks for you reply!
However, I want to get the mean velocity and RMS through UDF and thus I'd like to know which command I need to use.
Regards, sarah
Old   December 20, 2006, 10:44
justin
hi, I have the same problem as you. From my point of view, the mean velocity can be plot in xy plot. As for the RSM, you have to use custom field function, i.e.[u'v']=[uv]-[u][v], but I don't know how to use custom field function calculator.
Do you have any idea about it until now?
Regards Justin
please help UDF for velocity profile in y-directio raju Fluent UDF and Scheme Programming 6 April 12, 2019 23:21
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
UDF for velocity farne FLUENT 1 February 25, 2009 00:29
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 18:29
Velocity LES UDF Lourival FLUENT 0 April 15, 2006 07:32
