-   -   Static and Total Temperature (http://www.cfd-online.com/Forums/fluent/42995-static-total-temperature.html)
Tomislav December 1, 2006 10:58
I am simulating the heating and natural convection of Heavy Fuel Oil in a tank. I obtain different values for Static temperature (300 to 420 K - the expected range between boundary temperatures) and Total Temperature (300 to 326 K). Shouldn' t Static and Total Temperature be equal if the maximal velocity is 0.005 m/s? How can I explain it?
Ahmed December 3, 2006 05:14
Re: Static and Total Temperature
I guess you ought to start by explaining why the total temperature range is less than what you call static temperature
ravindra December 4, 2006 01:36
hi tomislav total temperature is the stagnation temperature and is the addition of static and dynamic temperrature. if the velocity is very less, the dynamic temperature becomes very less, nearly equal to zero, so at that instant the total temperature equals the static temperature. i think yours velocity is comparitively nery less, so that the static and total temperature may be of approximately equal magnitude, hope this will help
Tomislav December 4, 2006 04:24
Thank you for the reply. I know for this definition. That's why I am wondering about the difference between static and total. The velocity is 0.005 m/s, I think it is too slow to have such different total and static temperature
ravindra December 4, 2006 05:59
what is the actual difference it is coming to your solution? can u help me in getting some tutorial of fluent regarding compressible fluid flows? supersonic compressible flow through nozzle i want rocket.msh and mprof.c( udf for this )
