Post-processing of a curved surface
Old   December 4, 2006, 13:46
Default Post-processing of a curved surface
alex
Hey, I have a semi circular pipe with flow going through. The curved surface is set up as a separate wall to the remainder of the pipe. When I display contours and view the pipe from above (i.e. plan view) the sides of the pipe are, of course, not visible. Is there any of displaying all the information including the sides of the pipe in one image i.e. to unwrap the curved surface?
By the way, I'm using Fluent ver. 6.2.16
Thanks in advance,
Old   December 5, 2006, 03:32
Default Re: Post-processing of a curved surface
Ralf Schmidt
Hi!
you may use xy plot, with an edge as x-axis, that is surrounding your geometry.
Hope, it helps a little
Ralf
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
Post Processing of Turbine blade cases screech1987 Main CFD Forum 0 March 31, 2011 18:59
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
