Deactivating Turbulence model
Old   December 28, 2006, 11:19
Default Deactivating Turbulence model
Avinash
hi,
I am adopting a new turbulence model in FLUENT using UDF.
For this I need to deactivate the k-omega models of the Fluent Source code and I need to define a new transport equations for the k and omega equations.
If any of you have an idea about how to deactivate the k-omega equations of the fluent, please let me know.
Regards Avinash
Old   December 31, 2006, 22:34
Default Re: Deactivating Turbulence model
Venkatesh V
HI, I am not sure whether this option would help you. You can model the fluid zone as porus media. Assign zero resistence for porus media and you can apply Laminar Zone option.
Old   January 1, 2007, 13:24
sujith
I hope you can solve the transport equations using the UDS faciltiy and then provide the turbulent viscosity using a udf.
--Sujith S Nair
Old   January 5, 2007, 03:37
flga
Hello Avinash,
Here you can see an example of a new turbulence model implemented via UDF. I hope it helps.
http://www.stanford.edu/class/me469b...rogramming.pdf
flga
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
