Laser Irradiation
Old   December 17, 2006, 00:23
Default Laser Irradiation
Mauricio Sanchez
I am trying to simulate laser irradiation in tissue. I am confused how to set the problem. I understand that this is done through the DOM model using semi-transparent boundaries, but the cases I have run do not match my experimental data. If you have ideas to set this problem correctly, please let me know. In my case I have a 5-mm diameter laser beam with power of 2 W/cm2. This beam should go through the medium when is incident upon a wall. THANKS A LOT
Mauricio
Having trouble with the modelling of Fluid flow during laser welding! nadeemxs FLUENT 2 August 4, 2017 10:01
help on radiation model for a moving laser beam nazeem FLUENT 1 April 20, 2009 10:34
Laser Heat Flux & UDF Dominick FLUENT 3 February 12, 2004 15:46
Laser Modelling Korcan FLUENT 0 September 4, 2003 03:38
laser irradiated molten metal pool kiran FLUENT 0 June 17, 2003 14:18
