-   -   STL file import to GAMBIT (http://www.cfd-online.com/Forums/fluent/43164-stl-file-import-gambit.html)
Spyros Stamatelos December 18, 2006 17:00
Hey guys, I am trying to import an STL format geometry file in GAMBIT but it produces an error: 'Error encountered while reading the header information'. I have also tried to convert the file via the fe2ram command but it did not work either. Moreover does anyone know how to transform a STAR-CD format file (.cel) in FLUENT format?
Thanks a lot for your help I appreciate it
Spyros
Michael B December 19, 2006 05:56
Re: STL file import to GAMBIT
If you have problems with STL or other formats, try to read it into a CAD package to see what's wrong.
Darthvader December 25, 2006 08:45
The file header is probably corrupt. Check the file again
Kevin Shanley January 11, 2007 13:20
Hello.
I am getting the same error.
The header doesn't appear corrupted; what should it look like?
Thanks, Kevin
