Home > Forums > FLUENT
Help needed
Old   December 21, 2006, 08:31
Default Help needed
David
I am running LES of turbulent channel flow but am going to put a trip in the flow to generate the turbulence before running LES. Any ideas of how i should do this and what size the trip would need to be.
Thanks in advance
Old   December 21, 2006, 09:36
Default Re: Help needed
hugo
Hi David
If you are running LES, why you don't use in the inlet one of the Fluctuation Velocity Algorith; you have the Vortex Method and the Spectral Synthesizer. In the Vortex method, for example, you can specify a number of Vortices in the inlet. Then you have a turbulence Specification method and there you can use k and epsilon (from RANS), turbulent intensity, length scale, viscosity radio, etc.
Good luck
Hugo
Thread Tools
Trackbacks are On
a CFD software is needed... maxgzc Main CFD Forum 3 September 27, 2011 01:51
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
Citations Needed! Roberthealy1 CFD-Wiki 3 August 13, 2007 15:19
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 04:09
CFD Software Engineer needed in Fort Worth, Texas Ross Main CFD Forum 0 November 19, 2001 15:48
