November 25, 2006, 17:53 |
porous media with variable porosity
Hi all, hope someone can guide me. I am trying to implement a porous media model with random porosity using the Eulerian model, so far I have implemented the initial porosity distribution modifying an example UDS. My problem is, what do I have to do to keep the porosity fixed during transient calculations? by using a UDS so the porosity distribution is read at every step?(that seems to me quite inefficient to say the least)
Please guide Thanks in advance Kev |
December 7, 2006, 22:43 |
Re: porous media with variable porosity
Hello Kevin, I am working on a problem I think is similar to yours, I have a 2D cylinder with a moving top wall (only moving down) and a solid stationary bottom wall, the 2 walls on the sides are pressure outlet boundary conditions. in the interior of the cylinder, I want to have a porous media (can I also add fluid in the porous media). As the cylinder comes down, the porosity should should decrease (does fluent do this automatically internally or do I have to define a UDF), as a result fluid comes out through the presure outlet boundary conditions. I have been reading fluent tutorials and so on. Can this be done and can someone help me with this.
Thank you |
December 8, 2006, 03:53 |
Hi Kevin,
I was trying to set a porosity distribution with the example udf also! But somehow, i didn't succseed. Could you please send me the udf you are using?? To: RSchmidt@iwt-bremen.de Thanks a lot Ralf |
December 24, 2006, 10:56 |
Dear, I want to work on project using fluent but no idea about the capability of such soft for porous media modeling.
Display Modes | |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
